Question for Moutainhorse and others
I have been tossing around the idea of gearing down a 2012 PRO RMK 600 with Carl's Cycle 660 kit and Carl's clutching. I'm not concerned at all with top speed. Would like your opinion on this also i'm a little confused on clutching I already have Carl's Clutching kit. Would I need them to redo my clutching if I gear down? I would like to hear from anyone else with an opinion on this also and remember this is a chain case sled so the cost will be reasonable
I geared mine down but im runnin a CE 2.5 and TATERS PORTING did my cyls
and im runnin 61 grams total in SLP MTX58s
I run 19/46 on my chaincase 800s. 74 pitch chain if I remember correctly.
Allows the belt to run higher on the primary-- more surface area to grab the belt--less slipping/ less heat.
I'm sure I lose a little top end but I don't run 70 mph on trails.
Clutching is TRS (here on Snowest) spec.
If you only gear down a little your existing clutching will probably work. If you gear it way down you might have to adjust your clutching some. Remember the secondary clutch is a torque sensing clutch.
