I recently purchased a new exhaust system for my M8 and took it out for it's maiden run today. No leaks from the donuts or from the exhaust gasket area. But there appears to be a small line of oil originating from the weld area where the y-pipe is welded to the base flange. Actually two pinholes the other is right across from it. Both are on the PTO side.
Is it worth sending the y-pipe back and getting another set of gaskets and going through the pain of loosening and tightening those bolts from hell (real tight area to reach) or is there something I could put on it to seal it up or maybe even put a tackweld over the area in question? I mean it is only a pinhole based on the amount of oil leaking, your thoughts.
