B
born2sled
should you fill the oil line with oil before attaching it to the crank fitting it is the oil line that runs from the oil resevoir to the crank middle fitting it is for the oil gear resevoir, that lubes the worm gear i do believe. There is oil in the oil gear resvoir but i know if people do an oil injection delete the tube that goes from the little container with oil in it or what ever you use to the crank fitting is to be filled with oil so you can make sure oil is in there, but i still have the oil injection hooked up but not sure if i should fill that line up or not
