Q on adding wheek kit to Pro
ENDO1
I have a 15 Pro with the clicker shocks, was going to add wheel kit but it looks like the clicker reservoir on the rear shock will hit the wheel when the sled is compressed, looks like I can only put the ones on further to the rear or am I looking at it wrong ?
Can you add xtra wheel on the inside of the rail, If you mount the shock absorber the other direction?,(with the clicker container up..)
I want to keep the icescratchers on my -15 pro163"
Wheel Kit
My 155 2015 LE came with clickers and all 4 wheels and scratchers installed. All wheels were on the outside of the rails.
Your looking at it wrong. All wheels in the kit go outside the skid. The front two don't go in the hole where the scratchers are mounted. I think the directions show that they do, however they don't. They go in front of the scratchers so you can use the scratchers and all 4 wheels at once. No drilling required. The holes are there from factory up in front of the scratcher mounting holes. Hope this helps.
