Push turbo issues
P
prairiepowderhead
I was out riding today and my nytro started running like crap and I noticed that the lights were not all working on the control box. All the lower numbers were but the Blue light would never come on while riding. and it is making boost but the lights are not coming on under boost, so I figured that I am not getting the extra fuel I need while on boost. What do you guys think. Is there a reset on the bos or maybe moister in the connections?
I would check the hose that goes from the controller to the plenum or whatever they call it. Mine was cracked in several places so the box does not know there is any boost.
I checked that too. I let it set for a couple hours and tryed it again and it worked flawlessly. I just want to figure it out so it doesnt happen back in BFE
get it in a warm garage and dry everything out. if the controller is outside on the handlebars move it under the hood on the radiator shroud. rarely needs to be tinkered with anyway no reason to have it exposed. If you suspect you have an intermittent box you might want to consider getting a spare from Push. These boxes have been extremely reliable as the newer ones are dipped and water resistant
