Chance are that you got a bad box , they do have a high failer rate , my last one lasted 15 - 20 minutes and when i called about it , the first thing i was ask is , dont you have a spare , well thats all it took , sent it back and took my sled to Mitch at at Synergy , he did up one of his fuel / timing box for my alpine turbo apex ( a few changes by Mitch ) we set the sled up on the dyno , ran up to 24 lbs boost on C12 fuel , A/F in the 12 .5 range with no knock on the parker knock box.
Could never do this with the Pure logic fuel box could not run it above 18 lbs and keep the A/F in range and the knock box would be going off, if you increase the fuel rail pressure to give more fuel on top end then the bottom end could not be keep in range ( rich ) With Synergys box Mitch can add or take away fuel and or timing anywhere thoughtout the map.
Before taking my sled to Mitch it worked good ,but did not start to build boost until 7000- 7500 rpms , i could be going down trail at 70 -80 Km/H and not have any boost ,when mitch got done with it , it works unreal Starts building boost at 4300 -4500 rpms , responce is unreal , it buildes boost on trail at 25-30 km/h now , i am glad i got piss off and did away with the pure logic box and its SPARE , haha .
Gunner
