Pully?
does anyone know the company that builds MPI's pullys? MPI must buy them from a big supplier somewhere. they gota be just a industreial pully that i could buy straight from the factory. thanks
ford
They are a commom TAPER LOCK bushing that you can get from any bearing supplier. they use two styles ( 1008 and 1108) and different shaft sizes. The drive is 7/7 and the S/C is 3/4.
We have broke two of the in the first 5 miles. Make sure you clearances are 5 thou. on each sides and top of the woodruff key. Torque them then run the sled, retorque, tap on the inner taper lock lightly with a punch and retorque and do it again. That is the only way I could keep them tight. I also torqued them to 85 inch pounds.
They are working good now.
The Pulleys are built by MPI, not bought over the counter somewhere.
jw
