goridedoo Well-known member Premium Member Dec 29, 2011 #1 Need to pull the secondary on my pro and I havent ever pulled one on a newer sled. Assuming its just the one bolt and then it slides off? And what how many lbs do I torque that to when I put it back on? Thanks
Creek Chub Well-known member Lifetime Membership Dec 29, 2011 #2 Secondary Torque 17 FT LBS Make very close note to the washer stack on the front and back of the clutch. They need to go back in the same order. PVT System Fastener Torques Fastener Torque Note Drive Clutch Bolt (All Carbureted) 50 ft-lb(68 Nm) Re-torque after running engine. Drive Clutch Bolt (All 2007 - Current CFI) 80 ft-lb(108 Nm) Driven Clutch Bolt 17 ft-lb(23 Nm) Team Helix Fasteners 60 - 80 in-lb(7 - 9Nm) P2 Cover 12 ft-lb(16 Nm) Team Deflection Jam Nut 110 in-lb(12 Nm) DO NOTOVER-TORQUE P2 Deflection Cam 12 ft-lb (16 Nm) P2 SPA Deflection Adjuster Screw Lock Nut 10 ft-lb(12Nm) Spider 280-300 ft-lb(380-406 Nm) Apply Loctite® 243™ OR Loctite® 242™ with Primer N™ Spider Jam Nut 290-330 ft-lb(394-447 Nm) Drive Clutch Cover 100 In. Lbs.(11 Nm) Starter Ring gear 150-180 in-lb(1-1.2 Nm) Apply Loctite® 271Use cross pattern
cascadesnowjunky Well-known member Lifetime Membership Dec 29, 2011 #3 Also the torx head screw on the lower body panel has to come out so you can flex it enough to get the clutch off.
