Yeah the 900 and my primary.Which sled? The 900 in your sig?
Which clutch? The primary? Check the link below for a location to buy clutch pullers.
http://www.hiperf.com/acatalog/Snowmobile_Parts_Clutch_Pullers_195.html
Yeah i guess i just really need to know where to get a decent puller..you wil need a wrench that fits the clutch center bolt, a CLUTCH PULLER, and something to hold the clutch from spinning without marring theclutch, like a piece of wood or a properly placed pry bar! or go and buy a clutch holder, SLP sells them
Im praying ill get lucky. If i cant get it i dont know what im going to do. hahaI just go mine off for the first time a few weeks ago. I had read on here it would be a bi&*h, but I didn't think it would be that bad.
I used a 3' cheeter and a buddy on a bar (wrapped for protection of clutch) holding the clutch. It nearly took the threads off the puller. The puller nose was pretty tweaked as well. We had put penetrating oil in with sled on its side and packed the hole full of grease. That did not work.
Finally, we filled the hole with penetrating oil, left it a week on its side and wrapped the threads on the puller with pipe tape and prayed. Cranked it tight and with a slight tap on the puller it finally let go.
Thats what worked for us.
In hind sight, we should have let it soak for a week to start with. I think that is what did the trick.
Good luck.
