PSI Big Air Carbs 46mm
THESE CARBS ARE 46MM PSI BIG AIR CARBS SERIES XI IN GOOD SHAPE. ALTHOUGH THE INTAKE SIDE OF THE CARB HAS BEEN GROUND OFF TO ALOW ROOM IN A TIGHT CHASIS. THIS DID NOT EFECT THE PERFORMANCE OF THE CARB AT ALL. THERE ARE ADAPTERS FOR THE ENGINE TO THE CARB, THROTTLE CABLE, SMALL AND LARGE FLOAT BOALS AND HIGH AND LOW ELEVATION NEEDLES. THIS IS THE HOLE DEEL, IF YOU BUY THIS FROM PSI IT WILL RUN YOU UPWARDS OF $2000 WITH THE EXTRAS. I AM ASKING $800 OBO IF YOU ARE SERIOUS LETS TALK.
SCOTT
Wood Buffalo-20111014-00185.jpg Wood Buffalo-20111014-00186.jpg Wood Buffalo-20111014-00187.jpg Wood Buffalo-20111014-00188.jpg Wood Buffalo-20111014-00189.jpg Wood Buffalo-20111014-00190.jpg Wood Buffalo-20111014-00192.jpg
