It really depends what your main riding style is and what type of terrain consumes your riding time. I spend a lot of time (especially in the spring) riding steep hard rutted make it or break it narrow chutes and if anyone gave me a 36" front end I'd give it back, I prefer 38" or 39" at a minimum. If you gravitate toward tree riding you will more than likely prefer the 36", much easier to lay over. Just because a manufacturer and the industry is making an effort at steering the riding culture to the trees doesn't mean it's for everyone.
I would suggest 37" raptor or kmod set up. By far the strongest front end out there and the shocks dont bind unlike all the 36" kits
I do, my cousin just installed his set yesterday. He will try them out in a couple of hours.Anyone run the Trenchers set. They are high clearance. Made in Canada way it looks.
I love it but I can't compare to the other brands since I haven't ridden those.You like the handling. Also should a guy order extra joints. Is that a braking point.
Same setup kept the sway bar. Unless you have progressive rate shocks or spring's you're severely limiting the performance of the front suspension without the bar. On edge, there is a tremendous amount of weight on that single ski. Without the bar or right shock, you're left with limited travel to absorb impacts. Double so on cutting an edge going downhill.I put the alternative impact on my 16. So far I really like it. Started out with no sway bar. Put it back on a couple of rides ago. Think I will take it back off.
