programming pcv question
sarpy
New member
can I install new fuel map on pcv with the pcv unit sitting on my desk. Not sure if it needs to be plugged into the sled while being programmed?
thanks in advance,
chad
I am pretty sure that as soon as you plug it into your computer, you can read and write to it. It doesn't need to be in sled.
yip.... the PCV can be programmed on your desk. it draws the power from the USB connection.
just plug in and send map, install and pull trigger.
-B
