$275 without backing plate, $350 with backing plate and new bearings Shipped to lower 48 states. I have a BDX magnesium chain case cover, heavy duty chain and sprockets, and OSP manual chain tensioner for sale. Cover has a speed sensor installed already and has a drain and dipstick for checking the oil. It's intended to be used with a oil injection delete kit, but BDX sells a small oil tank you can add onto it now. Chain is not HYVO but much stronger than the 2012-2015 stock setups and uses a steel lower gear instead of the stock aluminum one. Sprockets are 19/50. I only removed these parts to go to a belt drive setup. Cover was used for 750 miles and chain and tensioner have 300 miles on them. No scratches, scuffs, or damage on parts. These are for the pre-Mountain Cat drop and rolled chain cases. Also have a pre-Mountain Cat chain case backing plate that's drilled for the tensioner. Links to what the new parts are:
Cover: http://www.bd-xtreme.com/index.php?id_product=30&controller=product
Chain and Sprockets: http://www.bd-xtreme.com/index.php?id_product=324&controller=product&search_query=chain&results=29
Tensioner: http://www.ospracingparts.com/arctic-cat-procross-f800-heavy-duty-chain-adjuster-manual/
Actual part pics in post below.
