Proclimb 800 SLP Cylinders/Exhaust Stage III
XFIRE800
Getting rid of my pro climb to snow check a T3 XM. I have an SLP stage 3 kit on my sled (SLP Porting $610.00 and their pipe/y pipe/ and can $699.95). I will sell either separately, but i would need stock cylinders, head and exhaust valves in exchange for my ported cylinders, slp cut head, and exhaust valves. The pipe has a few marks on it from my bdx hood rubbing on it. It was also professionally welded in a small spot by the y pipe because i did not like how the weld looked from the factory (I bought the pipe new). There is about 1000 miles on the kit and it is a ripper. I also have a power commander V without timing control (379.99) and Digitron EGT's with quick response probes ($300ish). I would sell the cylinders (trade), exhaust, and PC V for $1000 and the EGT's for $175.
Separately:
Exhaust: $450
Cylinder swap $400
PC V $250
You pay the shipping on everything.
I ran the bdx intake with the kit for a while and that ran good, but i melted a hole in it so i switched to the stock intake and felt that it was a bit snappier and more consistent running. I am using Dakota Performance clutch weights and a yellow/white spring for 6-10k. I would sell the weights for $100. The PCV also has the SLP Stage III non-ethanol and ethanol maps loaded onto it. This kit turns the sled into a monster with stock reliability. I ran it from 3000' in northern montana to 12k in southern colorado with the same map and it is definitely a runner. Had trouble with clutching early on, but once that was figured out it was good to go (stupid cat clutches). Call/Text 605-252-0840
Someone shoot me an offer on the cylinder swap! Wanting to sell this sled soon but would like to have stock cylinders on so guys from the midwest can buy and ride at home if they want to. 605-252-0840
I am interested in your slp kit as a whole ready to run. I have 600 miles on my sled and would swap stock parts. What is your bottom price for all necessary parts and me sending my stock parts?
