Hi
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
I have a problem with my XF1100T. Between 3500rpm and 5500rpm it has a point it is "backing/cuts" out and the comes again.
See video: http://www.youtube.com/watch?v=_w-iVtX2Bbg
The problem is more clearly when the engine is at operating temp.<o
></o
After 400km (248 miles) my voltage regulator stopped working. That is the only problem I`ve had with the sled.<o
></o
The problem started around 1400km (869 miles) and the sled has now around 2300km (1429 miles).<o
></o
Mods:
TD 2,5" full Exhaust <o
></o
Hi Jacker 2.0 without rev limiter flash<o
></o
EVO BOV<o
></o
Clutching dalton T1<o
></o
Have tried to put it all back to stock. Didn`t help.
Things I have changed from a M1100T 2012 model:<o
></o
Plugs gapped at 0.22. Tried new ones as well<o
></o
ECU<o
></o
Display<o
></o
Fuel pump with pick ups<o
></o
Fuel injectors with regulator<o
></o
Fuel filter<o
></o
Air filter<o
></o
Throttle body with intake, TPS and idle engine.<o
></o
Primary and Secondary clutch<o
></o
Compression test<o
></o
Leakage test in/ex valves<o
></o
All 3 sensors/valves located above the primary clutch.<o
></o
O2 sensor exhaust<o
></o
Disconnected throttle safety switch<o
></o
Have changed pretty much all components that are related to fuel. Fuel pressure ok. No impact on the fuel gauge when it happens. <o
></o
Builds full boost. But the sled feels like it has less response than the other M1100T I have tried. <o
></o
Checked Intercooler and hoses for leakage.<o
></o
Any thoughts?<o
></o
Thanks.<o
></o
<o
> </o
Mods:
EVO BOV<o
ECU<o
Display<o
Fuel filter<o
Air filter<o
Compression test<o
O2 sensor exhaust<o
Any thoughts?<o
Thanks.<o
<o
