problem with vector starting? need help!
i just rebuilt my 2006 vector and got everything hooked up and it wont start? when i put a little gas in the cylinders it will fire but wont run. i tore the carbs apart and checked all jets (in case they were plugged) and that didn't change anything. gas is getting to the carbs and into the bowls but the plugs r dry so its not getting to the motor. anyone know what my problem could be need help! thanks
Cam timing?
Yea timing. If your valves are opening to late it might not have enough vacuume to suck the air fuel mixture through the carbs. By he carb uses a venture effect. As air rushes through the carb it picks up gas. So not enough vacuume/air flo, no gas.
well my timing was off but it is on now and i am getting fuel and it will kind of fire but wont run. i was told that when my timing was off that it could of bent a valve and that is why it will fire but not run.
