Problem, Freezing Throttle
At the end of the day my throttle was freezing open. Not all the way but a little. Does anyone have a solution to this. Any lubricant or something to keep this from happening.
Thanks.
What kind of sled do you have? I have a 07 Summit, and it has stuck on me a few times. I have lubed the cable, sprayed the carb rack with WD-40, and run the carb warmer open, and still have had this problems. If you own a Ski Doo this seems to be a problem. If you look at the forum, under Ski Doo, you will find many posts on this topic.
Is it in the cable or the carb. If the cable maybe have a bit of water/moisture in there, try some IPA, Isopropyl alcohol(rubbing alcohol), down the line to get the moisture out(use a squirt bottle to get it down the line). Need to get the water out first and foremost, then any lube should work. ANy lube no matter what if there is water in the line, will matter, need to get the water out first.
Thanks, will do!
