E
Einar74
Hi
A friend of mine has a Nytro with MPI stage 1 supercharger on it. He recently bought this sled in USA and shipped it to Iceland.
The sled is tuned for 7-9000ft on 8-9 psi. He wants to run this boost setting and is going to run AVgas in it at 0-4000 ft.
We went to today and tested the sled for the first time at maybe 1000ft.
Now for starters the sled run fine and never mist a beat during the short runs. But as expected the air-fuel radio was to high and it was reving to high.
Air/fuel was 14-14.5( prologger) and the rpm around 9100rpm. boost speaking 10+.
Now when we where going to add fuel with the Gems fuel box ( both have no prior experience with fuel boxes) it didn´t change anything adding fuel as the gems manual said. I started go into "red" mode and added fuel and even turned it all the way to "8" I didn´t see any difference on WOT. the "red" setting was on 4-5 when we started.
I then went to mode 4( fuel on boost) and set that to max and nothing change. Simply it didn´t matter what I played with the fuel "lights" or what mode, the sled run the same.
Could it be that the fuel pump and maybe injectors don´t support 8-10 psi at low elevation? but if so the air/fuel didn´t lean any more when I turned the "red" lights down again.
Regarding the clutching, can the adjustable screws be bought only, to add weight to the clutch or needs the weight to be replaced completely. to get the rpm down to 85-8800.
Do you know how much weight have to be added?
thank you
Einar
thank you
Einar
