Is a 200 CM probe long enough?
Thanks!
Thanks!
Thanks!
I have the biggest heaviest probe I could find, 320 CM long (10.5ft), stainless construction. The 200 Cm is around 6.6 ft long. The probes that come in the shovel handles and such are too light weight / short to be used in avy rescues. No experience there, but that is what I have been told by the instructor when I took the classes.
Just some info, but it would probably be wise to get another opinion from someone who has done a lot of work in avy rescue and use there recommendation.
On another note, stay away from plastic shovels. Get a good metal shovel that has a reinforced connection for the tube handle on the blade.
200mm works for me!
I have stopped buying online when I can and buy local. Support the locals! It is sometimes difficult to do, as there might be large price differences, but most times the local shops will bring the price down, and you actually get to see where the profit of the shop is going. Right back into your own community. Just some thoughts, plus they can steer you in the right direction as far as gear is concerned. I think there are a couple of shops in the North Bend area.
I didn't even think of the local shops!! Duh, Thanks!!!
You have a good one right in North Bend. Pro skier service. Martin Volkin (owner) is a back country bad a$$.
There's herbal pills you can buy off the internet to add length to your probe...
