Pro won't idle
R
rmk685
Took my new pro out this weekend and it ran excellent the first day. Second day started sled in morning and it ran for about a minute then died. It continued to do this all throughout the day. If I would completely dump the throttle the check engine light would blink then sled would die if I didn't get back into the gas. Had a bad bog from 5400-6200 rpm. I would assume it was over fueling as I used a full tank in about 40 miles. (only used 7.8 gallons in 55 miles the first day) I have a slp pipe with power commander on the sled with carls fuel map. I unplugged the powercommarder and sled still wouldn't idle, so thats not the issue. Third morning loaded sled and cruised around the lot and sled was back to normal.
Anyone have any ideas???
moisture in the connectors..take them apart, blow dry and put some dialectric grease on them...(tps,ecm,temp sensor, pipe sensor, most all connectors)
Stalling Pro.
Check the throttle cable free play. To much free play will make your sled run like the way you explained. :canada:
