Pro vs. assault
BigT
What are the main differences? Which do I want? Dealer telling me that the assault is a better option because of wider stance and higher clearance. Thoughts?
I was leaning toward a pro or SKS. Hadn't thought about an assault. Now I figure I need more info.
BigT
Do a search there is a ton of info on this topic, including pics and information and reviews on both of these sleds.
BigT
Depends on what you are doing with it
Sent from my SM-G930V using Tapatalk
For what it's worth I was in the same spot last year, what to buy? PRO RMK, Assault, or SKS.
I bought the Assault mainly for the more robust suspension. I planned on narrowing it up with ZRP spindles, but they are not available for the Assault yet.
In hindsight I wish I had gone with the SKS. It's a bit heavier but it has the narrower front end and most importantly it has an additional cooler that would be a great on icy days. I spent a couple days last year packing ice on the tunnel to keep the Assault cool.
Having said that, they are all 3 great!
Assault Has the following
Snowcheck Colors have more Choices
Chain Case (Gearing changes easy)
Negative Caster ( from Pro )
Clicker Shocks (5/8 shaft Fronts ) real Valving!
Scratchers Stock
2.25/2.6/3.0 tracks
Steel A-Arms 41.5-43.5 stance
No swaybar
Carbon Fiber overstructure​
Carbon Fiber Bumper (Stupidest idea ever)
PRO _
Belt Drive 2.4/2.6 tracks (Chaincase 3.0)
Positive Caster
Sometimes clicker Shocks depending year
Shocks soft Valved for Swaybar ( lousy calibration)
Scratchers stock
2.4/2.6/3.0 tracks
Aluminum AArms 39-41 stance
Carbon Fiber Bumper :eyebrows:
Sway Bar
SKS _
Chaincase
2.25/2.4/2.6
Negative Caster
Aluminum overstructure
Extra wheels in skid
Front Cooler
No Clicker
Aluminum 39-41 front
Sway bar Shocks same as PRO
Not sure on bumper ??
Probably mostly wrong info
