Pro shocks on 08 dragon
The pro track is the same.
You'll have to change the lower A-arms to fit the pro shocks
THE LOWER A ARMS ARE INTERCHANGEABLE , BUT THE SHOCKS ON A PRO ARE LONGER SO THEY WONT WORK .
You'll have to change the entire skid. A pro skid will fit in the IQ chassis no problem
Okay man thank you, I was looking for a less expensive alternative to aftermarket shocks. I have the walker air on the sled, I think I will just go with the raptors and be done with it.
Done Front PRO shocks to 2 Dragons (07 and 09) and all I had to do was make bushings for the SAE bolts and not use the metric bolts form the PROs. Also did the skid/shocks from 163 PRO to the 10 Dragon and works fantastic!!
gtwitch in wyoming
gtwitch in wyoming
What year of pro did the front shocks come from? I'm looking at a set from an 11 but there 1/2 longer than the stock ones which are 17". Would it be better to have them a little longer or a little shorter say from like a 13-15 pro?
I used a set of 12 Pro front coil over shocks on my 07 700 Dragon and this worked out fine making bushings (3/8" id) to go into the shocks to replace the metric ones (10 mm) at the time I think I just held the PRO shocks up against the WE air 07's and they were the same length so a year later I found a set of 13 PRO take offs on line from a guy who said he weighed 260# and needed to put more heafty shocks on his machine and these shocks had only 100+miles on them so I put them on the 09/10 Dragon 163 800 with the same exercise with the bushings and within a month I found a takeoff 163 PRO skid frame complete and got rid of the WE air shocks and skid frame (It is for sale with new hifax's) under the 9/10 Dragon. This completely changed the handling for the better and then within two months, I put an Iceage PROMOTION link on that sled and that is also worth doing on that chassis.
gtwitch in wyoming
Though the 13-15 pros had the same shocks. I need to put new shocks on a 09 rmk that I'm building for my son and I'm trying to figure out witch ones will be the best fit.
