Does anyone know of a swaybar quick disconnect for this model sled? If use, please form.
Thanks,
-John
Thanks,
-John
This one should work
http://www.teddunlimited.com/teddunlimitedswa.html
I'd call or email just to confirm though.
A couple wrenches for the nut/bolt, and some electrical tape?
Unless you plan to be going back n forth multiple times during the day..
But generally, you'll also need to adjust spring preload to resolve the diving that no swaybar causes.
It looks very simple to just get another bolt, drill a hole through it, and put a cotter pin through it as a "quick release" I guess.
Is there any reason u would have to disconnect both sides? I realize disconnecting one side renders the sway bar ineffective, but want to make sure I'm not overlooking something like if one side disconnected would the other side hit anything?
I built mine for about $5 at ace hard ware . 1 ft 1/8" cable 2 cable clamps,5/16 pin with multiple holes and a cleaves pin. Drill a 1/8" hole in the pin near the head run cable thru it and squish clamps on cable now cut cable to desired lenght make a loop at the end an install cable clamp, that end is for the cleaves pin. When not using just loop cable over the top of the sway bar and hook into cleaves pin done. If interested I will take some pic tomorrow.
