PRO RMK Pipe Question
R
RKT
Wanting to test a few single pipes for the 2013 Pro 800..
I notice that there are different part numbers for a 2012 vs a 2013 with these pipes.
What is the main difference?? Will a 2012 pipe fit on a 2013 ? OR is it a total "no go"?
Thanks in advance
What pipes are you going to test? If i am not mistaking, the slp pipe is going to fit all 800 from 2011 to 2013.
pipe
the 11 12 pipe will work on the 13 all you have to do is make a small bracket for the silencer to mount too i built one for mine, but i am running the stock pipe now and it runns awsome not sure i even wanna try the slp pipe agin the stock one runns really good
i was told by slp that there 13 pipe was diffrent than last yrs pipe. all new pipes will be made to 13 specs and will fit 11-13. dont know for sure as i havent personally checked.
we tested the SLP single yesterday..it is a shorter pipe but did fit with their can as well.. thanks for all the information
Just for information, today I do comparaison between stock can and ggb mountain can ,, switchback assault 2011 on non-ethanol plus ,no fuel controller, 1000ft altitude... test were in long flat field, 8000 rpm on long pull with ggb can and 8300 with stock can ..... the ggb can is really not good in combination with drop in kit !!
