I gotta do a little plastic welding on my hood on my 12 PRO.... Does anyone know what material the hood is made of??? I know the side panels are TPO but could not find anywhere on the hood what the material is.
I repaired the crack in the spring using the URETHANE SUPPLY CO. Mini Weld plastic welder. I used the stainless steel screen in the back and melted into the plastic using the wide tip on the welder. I covered it with the fibre-flex rod and then gouged the crack on the surface of the hood and then filled it also with the fibre-flex rod. Only problem is the finish of the fibre-flex rod has a couple holes about 1/16" in diameter and 1/16" deep.... I think I'll sand the surface off a little and then fill the holes and surface with the HDPE rod; that should give me a perfect finish then..... I think it's stronger than new now!!
