Has anyone figured out a good clutch set up for 10-12k ft elevation...225lb rider....thanks!
Did you have higher engagement with the MTX weights? I tried the lightening weights and they seem to throw out hard but "snapped" too much when in the trees. Almost like having a higher engagement primary spring.
try the slp green/pink and you will get the bottom end snap back...and still have the same finish rate..thats what we ended up with in the dragons to make them run....With the MTX weights we shimmed the spider 10 thousands...slp blu/pink and engagement is around 3500 most the time. The MTX seem to pull harder but they aren't as snappy out of the hole. Seems the 10-60's and 62's would wrap out faster but with less pull... rpm's are similar. Right around 8200 under a load.
Thanks Wyo, but i am no clutching guru....
