Pro Clamp Installed - Pics
deschutes
I installed the Pro Clamp drive shaft fix from Happy Face Recreational Performance Products today - www.hfrpp.com
It went on in 10 minutes and fit like a glove, the most time consuming part was removing the glue on the shaft that had seeped out of the hole. I would recommend a chisel and hammer, with a delicate touch and good angle through the track. The tolerances and fit on this clamp are amazing. Totally worth it to get on the snow today worry free.
I took a bunch of pics, trying to get some different angles. Hopefully this will help answer some of the questions on here about clearances and such.
Did your clamps bottom out on each other when you tightened the allen bolts? I think think they built them that way so you wouldn't over tighten.
am I wrong?
I think it is a perfect fit, and they don't quite bottom out, within thousandths. This is why it is important to torque them to the proper spec.
Looks great! I have got one on the way and their QC drive belt install studs. What is the distance it over laps the shaft?
Looks good. Thanks for sharing. Waiting on dealer to tell me to bring it in.
