A couple of tips on the intercooler install.
The 1/8" poly line that connects between the intercooler and EBC is a push in connection.
I needed to get a 5/16" 90* brass barb fitting for the fuel line that comes off the fuel rail. This line raises vertical off the fuel rail, so the 90* makes the horizontal turn, then 3" of rubber hose, and then your supplied brass T from the new throttle bodies. Use the hose off your old brass T for the extension.
The boost accuator on the charge tube mounts to the opposite side of the barbed fitting. You have 3 rubber lines at this connection the longest being the hose to atmosphere. I took the hose to blow off valve and used it for the loop from actuator to barbed fitting on the charge tube, the hose to atmosphere cuts to fit bov to accuator, and the left over is used for atmosphere.
When seat/fuel tank are removed, use a clamp on the large coolant line up near the top of the head and remove from head. Spin this coolant line around at the tunnel so it is out of the way for intercooler install. I lost very little coolant at the head.
Install fan after intercooler is installed.
Don't forget to change your boondocker box settings. I was putting everything away and realized that I had skipped this step.
