pro airbox removal
P
pura vida
so is it as difficult as it looks to remove the airbox on one of these new pros? haven't try yet, just looking. but it seams the a-frame needs to come out along with at least part of the steering linkage? since i am lazy... anyone have a set by set yet?
pv
They come out real easy the oil tank,ecm, support tray need to be removed. then disconnect the fuel lines and the air box comes out in 3 sections , there is a 10mm bolt on the right side of the bottom piece of the air box securing a hose.
thanks for the info. i had the sled on its side doing other things and thought that it might come out the side. so i pulled the ecm and oil tank. got distracted and stopped right in the middle for the night but was wondering if i could at least pull the top off and bring the box out the side in pieces. thanks.
pv
update:
well i don't know if i would call it easy. did what was mentioned above and got the horn and top half of the air box out. was in the process of pulling the bottom half of the airbox when i decided it wasn't worth the effort. did what i wanted to do by pulling out the first two parts. hopefully i don't have a real need to pull the airbox anytime soon. what a pita. thanks though.
pv
