I have a 2011 800 RMK that is cutting out after a run up to 8000 rpm. Sometimes it does it right away and sometimes it takes around 10 seconds. It runs strong to 8000 drops a thousand or so RPM. I have checked the power valves, solenoid, and stator and they all check out ok. It had a code for overvoltage to the pipe temp sensor and it failed. I replaced the sensor and the voltage regulator and it is still acting up. I have a known good 2013 ECU that looks like it will plug in but need know if anyone knows if you can just plug it in and not have to have it reprogramed.
I am also going to change the fuel filter and inspect the fuel pump lines and pick ups. Any other suggestions on what to look for are welcome.
