Can I prime the pump with aftermarket software, or a chassis power up harness? I have no dealer within a few hundred miles. The mag side rod Bearing is toast on my 850 and ordered a reman crank.
Thanks. is there an issue with the nozzles? Can’t see anything wrong but seemed like it had a restriction compared to others. I pulled it and swapping another One in.It’s not hard just make sure your main line to pump has oil in it the pump will pump to your engine I did this on my rebuild and it’s been going strong since day one.
Is this true for the 2019+ 850? The manual says that it must be done through the software…You can activate the oil pump to prime it by putting parking brake on, hold reverse button down and hold throttle wide open for a few seconds. It wil run the pump for a few seconds.
I believe you need power harness to supply electricity to the oil pump and ECU. Then do all magic button combination. EZ-LYNK sells a power up harness. They also sell a "tuner" that reads codes and allows you to reset power valves. I believe code MURPH10 gets you 10% off. FYI the tuner doesn't come with any tunes per say you have to buy those from other companies. I plan on picking one up myself so I can do my own maintenance. Oh if your a Ski-Doo guy that same EZ-Lync tuner allows you to program tether key codes. Then you can have a second key in your pack with the same code good to go in case you loose yours.Is this true for the 2019+ 850? The manual says that it must be done through the software…
Update for future reference:I believe you need power harness to supply electricity to the oil pump and ECU. Then do all magic button combination. EZ-LYNK sells a power up harness. They also sell a "tuner" that reads codes and allows you to reset power valves. I believe code MURPH10 gets you 10% off. FYI the tuner doesn't come with any tunes per say you have to buy those from other companies. I plan on picking one up myself so I can do my own maintenance. Oh if your a Ski-Doo guy that same EZ-Lync tuner allows you to program tether key codes. Then you can have a second key in your pack with the same code good to go in case you loose yours.
