Pretty common for a spring change either by a prior owner or even a dealership. Depending on several factors like altitude, track, type of riding (trail or Mountains), gearing, driver size, secondary spring, fly weight, helix angle ect. and your particular style will determine your clutching needs.
I never leave my clutching stock, even on a new sled.
I use a 160-290 on an 05 REV 151 for my elevation. 160-320 works better if I go above 8,000 feet.
160-350 sounds kind of stiff but not knowing your sled or other factors, it may be just the ticket.
Dyno Joe's kit uses a pretty stiff spring for the primary and changes the secondary helix. Maybe someone did some clutch tuning to your sled that you are not aware of.
