Ok so I bought a used primary with 5 rides on it supposably since it's last rebiuld. He had a clutch wieght come loose and take out a roller so I figured I could do a pin and roller kit myself and have a good spare clutch. I do have access to the tools to take it apart. So I took the clutch cover off and spring and the movable sheave seems to stick a bit as I slide it up and down, is this normal since it's not bolted to the cover or does it need a new bushing? Anyone ever tried taking these things apart, does that bushing just press in? Its for a 2015 proclimb. Also what are your thoughts on floating the secondary, does the belt run 50 degrees cooler like they claim? Are there any mods necessary to install one?
