primary clutch help
i was told to run 91 gram weights on primary with a different spring just because i have evo cold air intake . boost tubes . brv valve . highjacker 1.9 they say if not that my rpm will be tagging my rev limiter is some one pulling my leg ?
that sounds about right, I haven't installed mine yet and don't remember exact weight, but I had to change weight and spring because of EVO 215 and new can.
What elevation are you at?? At 5000 feet to 10,000 feet I can tell you that the 1.9 Hijacker will not pull extra weight.
mds weights
I amrunning mds weights at 87.5 grams, black polaris spring, and bdx 36/44 helix. Pulls 8100-8300 at 7000ft. evo215 plus same mods from evo as you. Very happy with the kits.
