I have a 2015 axys switchback,,,they use an 1177 belt that uses a shorter c to c than 2014 pro ride chassis. The c to c is the same as the IQr 10 5/8" I believe. Old belts like the 1115 won't work
The new belt is a better more durable compound, and will fit on the older model pro's. The new part number by the way will be 3211183 if anyone is interested. The 2016 also has a new Primary that has sheaves that are cut to match the belt angle better (exactly like the clutch mod that we developed here at Carl's), as well as helping to reduce belt heat. The belt will retail for 199.99 to the best of my knowledge, though prices may change as usual.
Good news that means that the cat 048 belt will work. @ $60 a piece way better option.
never thought id see a $200 belt
Will a 800 16 axys primary fit on a 800 15 pro? Or are the crank diameters/tapers different?
My vote would be for the Gates G Force C12 (Carbon Corded) belt PN# 44C4553; Which are readily available for nearly the same price (if you shop around) as the Cat 048 (but a much higher quality Belt).
With a Part number Google search you can find them from $75.00 and up. FWIW
