Premix Oil pump settings turbo
Hello guys, running 6 psi on pump gas at 190 hp. Hm kit with aero charger. My installer turned the oil pump 2 turns to richen it up. Just wondering if that was standard with other turbo kits. My plugs have very rich,black and oily. There is black oil in the pipe.
It's not the pump being turned up 2 turns... Lots of guys running 2,3 even 4 turns on the pump and not having fouling issues
You have to be either overfueling at a certain rpm causing it to bog, or you could have a spark plug wire that could be either not connected right or worn down. I know my sled has a wear spot in the spark plug wires from when it was stock and I just noticed it. Also the plug caps can look like they are on but they aren't becasuse they can be hard to push on.
