How many guys have deleted the oil pump and premix oil/gas,and what ratio do you mix at?
Did you drill the case to lube the water pump drive?
10-4 on the grease but then you gotta hope it will get greased when it is in others hands after it leaves.
i'm mixing 40:1 on the first tank then see how that is if it seems like to much i'll go to 32:1
I think you have it backwards, 40:1 is less oil than 32:1. Start at 32:1.
How much trouble is it to do the oil deleate?? Im rebulding a 2001 cat 800, that wasn't getting oil. I'm curious what it takes,, or if i should just fix the pump?
