Getting a lot of stuff taken care of for the 1st year of Snowbiking and would like to hear everyone's setups on the Honda's. Let's hear it !!!!
DittoI ran 0w 40 ams oil . I could not believe how much better my bike performed with it.
I ran my 2013 CRF450 last season as a snowbike for the first time. I used Rotella on both sides as I have always ran that in my bike. MAKE SURE that the oil you use is jaso-ma rated (wet clutches) as far as I know only 15-40 Rotella has that rating. I change oil after every ride as I have an over fueling issue because of engine temps and riding in the cold so I get gas in the oil. Hopefully that'll be cured this season.
I figured the 85w gear oil would have to be changed out due to the Cold. Here in NorCal we usually ride at 20-30 deg, not extreme as the Great White North! I'll start with the Rotella and see how it works. Thx.
Ams 0 40 also is good for wet clutches. My bike did not work very well with 15 40. My rekluse kept wanting to creep. Once I switched no problems
The rotella 15w is great warm weather about down to 40.... I find 4 strokes are very hard to start in the real cold because it is too thick... But the 5w semi syn works well.... 2 stroke it does not really matter just have to adjust the freeplay a little on the rekluse with the heavier weight... For me it is hard buying any expensive oil because you are almost changing the oil every ride to two rides... I think it is more important to change oil often than have the expensive stuff... With rotella these are the hours I have ran on different bikes... Everything looks great and oil looks good.... I am sold..
500 hours ktm 300
350 hours yz250f
100 hours beta 300
200 hours yz85
250 hours kx65
125 hour 150r honda
