I have an 08 800 t dragon. I have had the pistons updated and reflashed. Chain case gearing, tensioner, cover updated. I have replaced the left front motor mount bolt. Throttle body boot and plate has been done. And I have had the voltage regulator replaced. The voltage regulator did not fail but it looked like on the back side of the regulator it had been getting hot so I changed it out. Hyfax has been changed. The chain case oil, chain tension has been adjusted. The fuel filter is good and old fuel has been suck out. I am just trying to do everything I can to prevent any know problems or break downs. Is there anything else that you guy's can think of that might need to be a done? I looked at the back side of the ecm for any signs of it getting hot but it looked good, so I put it back on. Better board have been installed. Thanks for any feed back.
