Pre det help on BD
sledhappy
I am having sporadic det issues. I have an 11 pro BD intercooler kit with cold air intake. I just put in the piston fix it kit. I was running 2.5. Gallons of 111 Oct per tank. Ride between 7500 - 11,000 ft 6.5-7.5 lbs boost. Head light delete. (Looked at the det sensor not touching motor or anything.)
last year I was having these issues found the ebc was going on and off sent it to BD found some cracked wires thought I found my problem. ( last ride of the year) with the ebc replaced and the ebc is not turning off that I can see but still getting a det sensor. Played the the fuel setting mid and highs from 7500 up. Did not help up to 46 (high) at 8200. Fuel is new. Another t pro running same fuel no issues. I think I should have enough octane for boost application. It will pre det if I'm on and off the throttle or wide open.
Any help/ ideas would be appreciated. Two of my thoughts fuel pump or electrical short.
Thanks for your insight
Have you replaced your fuel filter? My brother was having tuning issues with his Dragon BD kit after a few years. Replaced fuel filter and it fixed it.
Check if the pipe is hitting on the bulkhead. I had to do some grinding to made adequate room for the stock pipe, haven't had a det light since. I am running very similar fuel mix/boost/elevations.
