I believe the slp is 3 pounds lighter than stock or same weight as stock with heat shield removed.
Hmm i maybe have to take you up on that bullydog installation. But are you certain that it will hold up in the long run against moisture and snow? The bullydog unit feels like it could get trashed in a snow envoironment.
Im pulling 70gram on my Stg2 with my 3"/163" at 15-2500ish feet. But need to put atleast one more magnet in. Wants to overrev during wheelies or when the "friction" is low![]()
With 76gram are you trying to hit 8300ish rpm or you still aiming to be at 8400-8500?
Your engine must be running extremly strong if you are able to pull those weights with the same springs as i do.
Overall happy with the kit. Pipe feels really rigid and wont crack on ya thats for sure...Really nice sound from it even tho im riding stock can. Not that awfull tincan sound that SLP is notorious for. More roam and grunt in the bmp pipe, without making more noise/dB.
Only downside is that it got a little expensive when importing to Sweden, especially now with the high value of USD.
Big plus side is the frikking amazing customer support. Had a problem with bullydog and after a walkthrough by Mike via videochat we solved it. My sdcard contact had a little to much siliconcoating on it so it had trouble reading the sdcard.
Might be looking into bigbore, y-pipe and can for next season if i keep the sled.
Yeah i also think the pink primary is abit to rough when it engages at 4.4k. Around 3.8-4k should be nice. Are you seeing 4k+ with teal or 3.9-4? I see they also have a 120-330, white colored. But that could drop it abit to much.
Thanks Mike. We drove 40 hours straight from Upper MI to Tucson AZ. We left in white out and it was @0 it's 80 here and their expecting to break a record @87 here today. We're getting some crazy looks with the two sleds on the truck with cactus in the back ground lol. I'm sitting by the pool now meanwhile just got a message that the snow in Da U.P just shut hwy28 down. We're headed to CO in two days.
Let me know how everything goes out west! Teal spring is definitely a better option for high altitude guys. Great finish rate to keep those RPM's up in high load conditions, yet low enough engagement so you don't trench.
Looking good! Glad to hear the BMP stuff is shining for you. just took the plunge and ordered the pipe for my starter kit lol.![]()
