POWERMADD Throttle Cable Extension
It is just ****ing ****
:mad:
checked there site they dont list a cable for M1000. Anybody know what the next best thing is for us M owners might be?
I used one for years with absolutely no problems.
They do add a bit more throttle trigger resistance but for what they are they work excellent if you follow the installation instructions exactly.
They will not freeze or fail if you install them correctly with the grease inside and seal the whole thing with the supplied heat shrink tubing and then seal the ends with zip-ties to keep any moisture out.
Moisture is what kills these. The water freezes and then you pull the trigger and ...snap.
Don't give the water a way in and you're good to go.
Cable frayed and broke on the two I owned...yeah lotsa fun to try to ride a sled out with the throttle on the bottom of the bars to get home...I went with GravityWorx and its been a great set-up!
Just give Darrin a call... I know he has them for the M series....
Great guy with great service......
