Installed a full SLP pipe set on a 07 1000 with a PowerCommander V before the season.
While in Cooke on first trip it would develop a studder around the power valves if playing in the trees if you let off it and grabbed a handful, also running a little lean on the trail around the power valves, programmer increased fuel in these areas.
On second trip went to YellowStone, really bad studder around powervalves.
On a wide open run across Hebegon Lake EGT's were around 1200 so I would just burp it so I did not have to stare at Gauges. On one of the burps I lost Pto cylinder, but by the time I slowed down cylinder came back on and ran flawless.
Worked with map maker the next couple days to get rid studder but it would come and go, we were thinking it was the air temp sensor location with the Timbersled intake.
Now to today, elevation 1200', temp 40 degrees, 57/63 gearing, stock silencer with a pod filter and a new stator installed.
Run 1, map a combination of my mapmakers and SLP'S
Top speed 79, lean around powervalves
Run 2, richened map around power valves, to rich to do anything
Run 3, SLP's Map
Top speed 80, but studder has returned, mag cylinder goes down.
Run 4, SLP's map, Stock Pipe
Top speed 79, Pto cylinder goes down
Run 5,PowerCommander unhooked, Stock pipe
Top speed 80, slight sound of a studder around powervalves, but nothing on gauges.
Run 6 map all zeros, stock pipe
Top speed 81, Strong sound of studder but nothing on gauges.
What part of this equation is giving me problems?
Or am I missing something real simple.
Run 3, SLP's Map
