C
crossfire879
I got a 08 M8 with ported jugs and shaved head. Since then twice now the clutch side piston has come in contact with the power valve. Its minimal contact because it never harmed the rings, just marked the piston. The first time I tried grinding the valve a bit but it never fixed the problem. However with everything apart and rolling it over by hand i can physically see clearance there?? Is it possible that the stopper inside the valve assembly is hammered out and letting the valve drop down too far momentarily while in operation? Even with the valve bolted into the cylinder and piston out i checked and the corner that hit the piston is no more than flush with the cylinder wall. The guy who did my porting is busy and i am having a hard tome getting a hold of him.
