Setting changes must be made with the engine running or with the vehicle powered by an external DC power supply connector.
YES..
It is the one 12 v DC White Plug
hook up 12 power... u can run gauge and lights
My Dealer gave me the run down on this. There is a 2 Amp fused connector in the hood harness for the cigerete lighter accessory, this should be used for DC powered devices such as a GPS. The connector in front of the oil bottle labeled DC PWR can be used to power the gauge when the engine is not running, but this connector should not be used for accessories.
For heated shields, the white connector labeled "AC PWR" up by the handlebars should be used. Polaris sells an accessory RCA adapter kit that connects to the AC PWR connector.
Good Luck
About this DC fuse is it the one located by the DC power up plug. Would I tap into right at the fuse to power koso gauges or where does this wire end up in the wiring harness.
Thanks
