Power Tilt snowmobile / 4 wheeler deck. Factory built, designed to carry 2 snowmobiles / 4 wheelers forward facing, no ramp, deck tilts to the ground for easy loading, anchor sleds down, lock the sled brake then power up the deck onto a steel frame for hauling. Pretty slick and very easy loading and unloading. Aluminum and marine plywood top deck with steel frame carriage that bolts to the pickup box floor. Leaves 4'W x 8'L x 2.5'H dry storage under the deck.
Tilt deck works with tailgate up or down and with empty or full storage area. Also provides easy access to under deck storage area when in load position. It also works with some trailers hooked up when trailer is jackknifed. It is designed to be used in an 8' box. Sleds stay clean up high to and it looks good to. No hydraulics to mess with. Single 12v motor mechanically runs the power assembly so it does require dual batteries, if you don't have a place under the hood there is room in the pick-up box for a second battery. I am going with a flatbed is the only reason I am selling it.
This rack also works very well to load and haul two 4-wheelers, Just ride them up, lock the brake, strap them down and power them up onto the truck.
$2200 cash,
cl add for pix
http://kalispell.craigslist.org/snw/5287199981.html
$2200 cash,
cl add for pix
