These new units will have the exact same look in the Customer Software as our fuel+ignition PCV's for the other powersports.
You will have one table for fueling, and one table for ignition timing. (Or advance this Map to have individual control over each cylinder) In the fuel table, Add up to 250% of fuel or subtract as much as -100% fuel.
Then, in the ignition table, you can advance up to +25* or retard as far as -25*. As always with PCV's, this will give control at specific conditions across the map based on RPM/TPS at 0, 2, 5, 10, 15, 20, 40, 60, 80, 100% throttle and from 500-9500RPM (if you can rev that high
) in either 500 or increase your precision to 250 RPM increments.
The two "Maps" capability I'm guessing you're referring to is most likely the two different Tables - one table being for Fuel and the other table for Ignition? These tables will be paired in the device, always together in the same Map - in the same enclosure.
Noteworthy, the PCV can store Two separate Maps (one for trail/one for trees) if you wish to install a map switch for toggling between them. This is also useful for nitrous applications where the momentary switch also couples in to switch the PCV map to add fuel when spraying nitrous.
There is a way to make timing change with altitude. This would require some other equipment to make this happen - but you can do it using the 0-5V analog available on the expansion strip of the PCV.
-An absolute pressure sensor having 0-5 output would be necessary and installed under your hood as a barometric reference...
-Run the signal of that sensor into the 0-5V analog hole...
-Set up the pressure transfer function (XX Pressure = XX Volts) for that particular sensor inside the PCV...
-Create a pressure table with appropriate columns (i.e.: 14.7PSIa = sea level, 12.5PSIa = 4500feet, 10PSIa = 10,500feet)...
-Create your timing(pressure) table to make timing changes per PSIa column corresponding to the elevation you are riding at.
The gains with timing being adjustable are numerous.
-The classic "hot mid-range" that these Arctic Cat's have can be retarded to bring down EGT temps making the machine more rideable.
-The fixed 3* flywheel Key won't be your limitation -- making your bottom end sluggish or the top end too hot.
-HP gains will come at the hands of kit builders and which modifications they feel are worthwhile. A pipe + intake + adding some timing might make for a better combination (rather than just the pipe+intake)
Thanks Everyone!
~T.J.
