I have a 2010 M8 with the SLP single and PCV with the SLP map installed. Overall, the setup works great. The problem I have encountered is that on three occasions on the last two rides the sled has started for a split second and then died. This happens on the hill with the sled fully warmed up. The only way I have been able to get it to start again is to disconnect the PCV and reconnect the stock configuration. If I immediately turn the sled off and reconnect the PCV the sled will again starts for a split second then die. If however I ride the sled for a few minutes with the stock configuratgion, I can then reconnect the PCV and the sled works fine.
I haven't had any problems with how the sled runs with the PCV once it is started, its just that it doesn't always start.
I have checked the PCV ground and connections to the ECU a dozen times, and I can't find any problems. I have checked the plugs when this happens and they are dry so I'm not flooded. Does anyone have any ideas or is my PCV defective?
Any ideas would be appreciated. Thanks
