Power additives 2001 summit 700
Im looking for help to make my summit better but i live in mn and dont get to mountains so i need stuff for around here. I want to make an old sled kick *** and take names
I just did a high comp head on mine and that woke it up alot. Porting, a pipe and running closer to lean will make power , but close to lean will also melt down if you have any issuses. power costs somthing and it is usualy life span and or relyability. I should add if you want power go to the bigger motor and do a big bore. Not sure if 700 and 800 share the same bottom end, if they do then look into big displacment jug and pistons.
700 and 800 are different size jugs . To get 800 jugs to fit 700 top case it has to be machined out.
