Sorry I know this is the wrong forum but figured the engine is the same. Anyway I have a friend with a 04F7 ext completely stock it had always ran good tell he took it out of storage last fall. It runs good unless you try and accelerate quickly and almost acts like its bouncing off a rev limiter at around 6700rpms. If you accelerate more slowly it will go all the way to peak rpm. It acts like a electrical problem but not positive.
So far we have rebuilt the clutches and swapped with a different one, replaced coil and plug wires along with plugs, checked the APV servo motor operation valve movement and cable lengths, and did the test on the stator per the AC service manual. We are running out of ideas and he doesn't want to spend money shooting in the dark replacing expensive parts. The local AC dealer only has a sled mechanic in the winter and we'd like to get it fixed before its time to go west.
